Shuts off at idle - Ford Powerstroke Diesel Forum
Old 04-19-2009, 09:01 AM
Shuts off at idle
My 01 just started doing this. Every so often, when I am at a light that takes a bit to change, the truck will just cut off. It will be idling fine then just shut off with no warning. Then it will just start right back up.
Old 04-19-2009, 09:28 AM
Does it just shut off as if you were turning the truck off via the ignitoion or is it a sputter and spit and then die?
Old 04-19-2009, 10:01 AM
It just shuts off as if pulled the key out. No sputter or spit.
Old 04-19-2009, 10:17 AM
Now im stumped If it spit and sputtered id say check your fuel filters etc, seeing as it just shuts off, it could be electrical
Old 04-19-2009, 10:38 AM
Check your cps sensor!!
Old 04-19-2009, 10:47 AM
second that
a spare in the glove box is cheap insurance
Old 04-19-2009, 01:02 PM
Is there a way to test if one is bad, or going bad?
Old 04-19-2009, 01:17 PM
none that i know of, just go to the Ford Dealer and buy one. $30 and a few minutes, then you will know.
Old 04-19-2009, 01:42 PM
the only one I could look up for the diesels was 152.74, the one for 36.06 was for the gas engine.
Old 04-19-2009, 02:29 PM
Powered by Deez Nuts
have you even done the recall for free?
