Head lights not working, 0.06 volts?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-19-2009, 04:34 AM Thread Starter
Hey guys
I got my truck out of the shop a few day ago and and discovered (at night) that my head lights are no longer working, every other light works fine.
i have HID kit and though maybe someone in the shop messed with them or something. they been working for the last two years without a problem.
First thing i checked was the voltage at the stock head light plug and it reads 0.06 volts.
Second thing was to check all fuses, they are all ok.
maybe a relay? but dont know were to look or test them
Ride: 2000 F350 XLT dually 4x4 CC 6spd
Location: Atlanta, Georgia (Sometimes i drive to houston)
Installed Mods: Tymar, TS6, 4" straight piped, Gauges, VeggieStroke
Mods waiting to be installed: none right now
kamaleon is offline
post #2 of 6 Old 04-19-2009, 05:16 AM
duct tape & zip ties
bigcountrysg's Avatar
Did you check the switch.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 6 Old 04-19-2009, 05:18 AM Thread Starter
didnt check the switch but was thinking about it lol. do i need remove the plastic dash cover or just pull out the switch
kamaleon is offline
post #4 of 6 Old 04-19-2009, 05:20 AM
Yes you will have to remove the plastic trim of the dash. It should just pop off.
2002 7.3L burnt
post #5 of 6 Old 04-19-2009, 06:31 AM Thread Starter
ok, i'll check the switch with a voltmeter and see if it's sending the 12v. Im thinking the switch only sends signal to a relay that powers the lights..
kamaleon is offline
post #6 of 6 Old 04-19-2009, 06:41 PM Thread Starter
it turned out to be a bad fuse, it looked ok but failed the continuity test... first big 30amp fuse
kamaleon is offline
