ICP and IPR question - Ford Powerstroke Diesel Forum
Old 04-16-2009, 05:11 PM
PMR = JUNK
Is the ICP and IPR the same for a 99-03 7.3 as an OBS? I'm pretty sure the ICP is but not sure 100%, and not sure at all about the IPR.
Old 04-16-2009, 05:56 PM
PMR = JUNK
Old 04-17-2009, 05:30 PM
PMR = JUNK
Old 04-17-2009, 05:39 PM
isnt ipr in the hpop have diagram in my hand as I speak 99/04 f series f350sd manual. then shows 1999-1999 (yes that what it says) then shows9c968 IPR onside of hpop
Old 04-19-2009, 05:51 PM
PMR = JUNK
So the IPR is different then? That post is hard to understand.
Old 04-19-2009, 05:58 PM
icp is not same for all years there is a break in the years
Old 04-19-2009, 06:53 PM
all ipr valves are the same ih # 1841217c92. there is an eng. ser. # break on the icp sensor. i think its 99 and below, and 99 and up.
Old 04-19-2009, 06:56 PM
I just went through this Friday ICP
International 94/95 1830669C92
International 96-up 1807329C92
Old 04-19-2009, 07:08 PM
PMR = JUNK
So if i took the IPR and ICP off a 97 it would work on my truck? Just verifying.
Old 04-19-2009, 07:10 PM
yes it should check the part number on both icps if they match your good 2 go
