no dash lights - Ford Powerstroke Diesel Forum
Old 04-16-2009, 10:33 AM
no dash lights
i have a early 99. and my dash lights and a/c light just went out one night. i checked the fuses and the ford dealer said the bulbs rarely burn out. has this happened to anyone else? if so what was it that caused it for you?
thanks
Old 04-16-2009, 11:36 AM
If it were me, I'd pull the cluster out and check the main plugs that go to it. Sounds like something came loose since they all went out at once. my second guess would be the dimmer switch.
Old 04-16-2009, 12:01 PM
Send a message via AIM to dana60axle
mine have been out for a year now ive had like 4 or 5 shops look at it no one can figure it out all that lights up is the door switches all the fuses have been replaced as well as the bulbs all the connectors have been checked if you find out id like to know also
Old 04-16-2009, 12:02 PM
i also put in a new dimmer switch and headlight switch
Old 04-16-2009, 04:35 PM
crazy. yeah all the warning lights work for the door and what not. im going to pull the dash piece off and take a look
Old 04-16-2009, 05:01 PM
Lifetime Premium Member
I just looked in the book and its showing a Lt.Blue W/Red as the feed for the instrument lights coming from the switch.You might want to check to see if you have power on this wire before tearing everything out.Hope this helps.
i was just out looking at stuff and do you guys think it might be the computer chip deal on the back of the insturment pod? after hearing was dana60axle was saying
Old 04-16-2009, 08:30 PM
i agree with him everything works on mine just no lights and yes ive checked i do have power just no lights
Old 04-16-2009, 08:55 PM
im going to run to the junk yard tomarrow and plug one of there clusters in if they have one handy and see what happens
Old 04-23-2009, 12:33 PM
i got a new cluster for a guy and still no dash lights. im going to replace the harness that runs from the light switch to the cluster next. and see if that works
