AIH Delete - Ford Powerstroke Diesel Forum
Old 04-15-2009, 05:50 PM
AIH Delete
I tried to search but all I get is foil delete. What do I do with the wires when this mod is done? Also I remember hearing that a plug from a dodge oil pan or something was the correct size for this. Thanks Kelly
Old 04-15-2009, 06:52 PM
Electrical Ogre
Yes a dodge oil pan plug is the correct thread. you can drill/tap it as well for a port for a boost gauge. leave the solenoid and wiring in place, just remove the power and ground that actually go to the heater.
Old 04-15-2009, 07:53 PM
dmd dmd is offline
I deleted mine, not a large difference but it does help. Spools up faster. Will have
to see how much it helps when pulling the TT. Anyone dyno before and after?
