Fishing for information here... planning on doing some heavy towing in the near future - was always taught that when an auto tranny starts to overheat to back off, pull over ASAP, and stick the shifter in neutral and wait with engine idling until the temps come back down-- basically trying to circulate the fluid as much as possible. I have met a few folks who just pull over and put it in park with engine idling, but I was taught to use neutral and wondering what the difference is. Also I know of at least one friend who insists on just shutting down the engine and letting it all sit... I see that as potentially catastrophic for any fluid trapped in an exceptionally hot passage...
Comments? Suggestions? Support? Disdain? Note I am aware of the benefits of and will be replacing my 7.3 tranny cooler with one from a 6.0 beforehand, but the question still stands on what to do once its too hot. |
First off, get the 6.0 cooler. Good choice.
Drive a stick!
Properly cooled/built auto will run/pull circles around a standard.
I was just about to say that.
Not a stick vs auto thread
Lets try to stay on topic here... as the person who started the thread I feel I have some responsibility to speak up and say that this is not the place for a stick vs auto thread, but rather for everyone that drives autos to know how best to cool them off when overheating. I particularly wondered if there was any benefit to idling in neutral vs park, thanks Dirk for your quick and on topic response. Much appreciated.
PSD fords run the trans pump all the time. There were/are some trans that only
run the pump if in gear or neutral, those need to be in N when cooling the trans. |
+1 more for the 6.0 tranny cooler. Direct bolt in and 130% bigger.
Aftermarket coolers are great, Hayden Transmission Cooler with standard installation kit * Makco Transmission Parts The bigger, the better.
+ 1 more for a 6.0L cooler.. it dropped my temps by 60 degrees
