will it hurt it???? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-14-2009, 06:16 PM Thread Starter
balistic's Avatar
will it hurt it????
ok I have a 2001 7.3, 140,000 miles ,mostly hiway, completely stock. I am now going to be pulling a 30' bumperpull all over Montana and Wyoming. I was looking at cutting the muffler off and welding in a straight pipe but I don't want to harm my rings due to less backpressure changing where my rings are seating at. I can't afford to lose any life off the engine right now but could use some cheap power and maybe help the exhaust side run a bit cooler. Anyone got some proffesional insight offer than "hell, I did it to mine and its fine"?? Thanks Brian
balistic is offline
post #2 of 4 Old 04-14-2009, 06:18 PM
no-tel-in's Avatar
no, man you will be fine, maybe even gain 15 hp, and it will not do a thing to harm the engine. There are alot of us in here that run it straight pipe.
Welcome to the .org!
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #3 of 4 Old 04-14-2009, 06:30 PM
Lifetime Premium Member
jbeasts10's Avatar
You should be fine.I pulled a 24ft enclosed trailer with a race car for a total of 26,000 miles on my 2000 F250..muffler delete was only mod.Never had any troubles.
2001 F250.Custom Tuned,Ball-Buster Turbo,5"Exhaust
ITP Reg.Return,TD Billet Converter,Built Tranny,Snow Meth/Water Stage 2..plus a few more things!!She will Hunt
jbeasts10 is offline
post #4 of 4 Old 04-14-2009, 06:36 PM
CSIPSD's Avatar
You will be fine. The turbo makes all the back pressure you could ever want. We are talking about a diesel here, not a gas rig. 4" turbo back exhaust can be had for less the $300 bucks. Do it once, do it right.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
