foil delete - Ford Powerstroke Diesel Forum
Old 04-14-2009, 03:46 PM
foil delete
what all would the foil delete do for the truck will it help it at all or just make it look better under the hood is it worth the time doing and if so how fast could someone do it
Old 04-14-2009, 04:15 PM
giving it a little
any opinions
Old 04-14-2009, 04:18 PM
It will just give a tad bit more whistle. And look nice
Old 04-14-2009, 04:20 PM
ok you wouldent happen to know and around about time on how long it would take to do it would you
Old 04-14-2009, 04:21 PM
Actually yes lol It probably take like 30mins unless your painting it. You just take loosen your ic boots from it and remove it and then start grinding the foil off or with a scraper scrap it off. The glue on it is the only bad thing about it... It just dont want to let go.
Old 04-14-2009, 04:25 PM
ok cool I was thinking about doing it cause it's kinda close to the ps pump pully and I pushed it over but I seen you can do it and I was curius to see if it would do anything ok thanks for the info
You hear the turbo really good in the cab. I love it, my mom doesn't like though. It makes the motor look a lot better and cleaner. It doesn't take long to get the pipe out, but it takes freakin forever to get that glue off it. I didn't have any cleaning stuff remove it with, witch I highly suggest a strong cleaner. It will be well worth your time. trust me! Any more questions just pm me.
Old 04-14-2009, 04:29 PM
yeah you can hear the turbo real good in the cab now but if it will do that it will be great the loader it is the better I like it but what kinda cleaner would you suggest to use on the foil glue
Old 04-14-2009, 04:30 PM
any kind of glue remover. Get a good kind.
Old 04-14-2009, 04:32 PM
goo gone maybe
