Has anyone here changed Turbo Shroud???? - Ford Powerstroke Diesel Forum
Old 04-13-2009, 07:24 AM
I am replacing my turbo shroud tonight, can any of you provide some do's and don't.
I see the e-clip on the wastgate is going to be a ***** already.
I will probably have to remove the Wastegate acctuator.
Can I leave the Ic tubes connected?
Thanks for the help fellas
Old 04-13-2009, 07:33 AM
Shouldn't take you very long when it's on the truck. I done several of them in place. Use a dental pic to get the clip off and then when you are putting the clip back on, tie a pic of fishing line to it so when you drop it (and you will) just pull it back up with the line.
Don't forget to adjust your wastegate........
Old 04-13-2009, 07:35 AM
How do I adjust the wastegate
Old 04-13-2009, 10:54 AM
You turn the end of the wastegate actuator to shorten the length, keeping the WG closed longer. Mine is full tight... it's a PITA to get it back onto the pin so be prepared to grunt and swear.
Old 04-13-2009, 11:00 AM
Ok, i'll give it a shot, Doing this and the HPO X-over tonight
Old 04-13-2009, 11:58 AM
Just pull the turbo to do the whole thing... It is so much easier to work on that bastard on a bench then hanging over the truck. Not to mention you can inspect everything else while your there.
