Injector Questions - Ford Powerstroke Diesel Forum
Old 04-13-2009, 07:05 AM
Injector Questions
Im in need of new injectors i have about 239000 on the stock one's , i see high egt's and hardly any power while towing , my questions is what would be a good injector , stock, stage 1, split shot, single shot ,hybrid
Old 04-13-2009, 09:22 AM
i want something that is good for towing, but still can have a little fun with the truck
Old 04-13-2009, 12:14 PM
Nothing your saying above leads me to believe you have an injector issue. You could have a turbo issue, a leaking boot or up pipes, a fuel issue... About a hundred different things other then injectors.
IF you just want injectors then thats differant...
Hybrids are the only way to go. With hybrids you can tune for 250 RWHP or 500+ RWHP... what ever you want. They will work with a stock turbo, or anything in between... No need for oil mods, or anything else.
But you need to find out what the cause of your high EGT's and no power. Its not likely your injectors.
Old 04-13-2009, 12:30 PM
I had this problem and it was my up pipes so u might want to check that out!!!
Old 04-15-2009, 05:08 AM
the reason i believe it is my injectors is i can hit 26 psi of boost and while running down the road i run 2.5 to 10 psi i have looked at my up pipes and dont see any soot on them at the turbo or manifold
Old 04-15-2009, 05:10 AM
how can i prove it is or is not one of the problems you all stated , because injector are very expensive
Old 04-15-2009, 05:13 AM
I am that hot
How long do injectors last. I have had the number 8 one replaced before I bought it, or the number 1 and 8 I am not too sure.
Old 04-15-2009, 05:18 AM
i have been told 100,000 and then they are toast but i dont know that for sure
Old 04-15-2009, 05:26 AM
I am that hot
I am at 209k and I have only had 2 of the 8 replaced, the others are as old as the truck.
Old 04-15-2009, 05:30 AM
yea mine are all stock with 239000 on then
