Installed new gauges, readings seem right? - Ford Powerstroke Diesel Forum
Old 04-12-2009, 01:51 PM
2000 f-350 crewcab dually, 4.10 gears 2wd.
boost at 55mph - 1psi max boost - 14psi
transmission stays at 175
egt at 55mph - 600 max egt 1100
the boost seems low and the egt seems high
only mods done to the truck is k&n intake and straight pipe exhaust.
Old 04-12-2009, 05:54 PM
Illiana Chapter Director
Everything seems about right. Boost might be a couple PSI on the low side but close. Around 16 PSI is normal.
Old 04-12-2009, 09:44 PM
seems about right.... once you get a tuner your boost numbers will increase...
Old 04-13-2009, 04:21 AM
Powerstroke Junkie
A stock truck should put out 15-17 lbs of Boost, check your intake boots.
Trans temps should be 70-90 above ambient, anything sustained over 200 means you need more cooling.
EGT's are fine below 1250, short bursts to 1400+ degrees is fine but nothing sustained over 1250.
To be honest this info is posted several times a week, the search feature can be your friend!!
NCH
