  #11 (permalink)
Old 01-18-2007, 09:03 PM
MartyB MartyB is offline
I run 80psi in the fronts, and 50psi in all of the rears. I run Rotella 15W-40, and a plain Purolator filter. My normal oil change interval is around 12-14k miles. Done this since new, and now has 188k miles with no smoke, and minimal oil consumption.
  #12 (permalink)
Old 01-18-2007, 09:37 PM
F-350MAN F-350MAN is offline
55 all the way around
  #13 (permalink)
Old 01-19-2007, 12:43 AM
Tacomarunner Tacomarunner is offline
95 in all six... Why are some running a considerably higher # in the fronts compared to the rear?? I know there is more weight on the fronts all the time, but what gives??
Russell
  #14 (permalink)
Old 01-19-2007, 02:19 AM
lilredpowerstroke lilredpowerstroke is offline
Im running about 25 in the front and and around 14 in the rear.
  #15 (permalink)
Old 01-19-2007, 05:20 AM
Russell
My truck drives better with 80psi in the fronts, and with 50psi in the rears, it doesn't ride nearly as harsh. With 80 in the rears, it rides like a wagon. With 50 in the fronts, it drives like a wagon. That's mainly why I run different pressures.
  #16 (permalink)
Old 01-19-2007, 06:03 AM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
In my dually, i run 80 in the front and 50 in the rear untill i get ready to put a load on it, then i pump the rears up according to how much load i am putting on the rear axle. If i am hauling 4k lbs in the bed, i'll pump em up to 80 but if i only have 2k lbs in the bed, i'll run 65 in them.
  #17 (permalink)
Old 01-19-2007, 04:27 PM
Deeno Deeno is offline
That's a good idea. I bet it does steer better. How do your tires wear with those pressures?
  #18 (permalink)
Old 01-19-2007, 05:38 PM
The tires actually wear really nice on the truck with these pressures. The fronts wear about as even as you can get, and surprisingly the centers of the rears wear a little faster, but nothing to be concerned about. I run Michelin LTX M/S's, and got about 80k miles out of the last set. I don't tow a lot, so it is pretty easy on the tires.
  #19 (permalink)
Old 01-19-2007, 05:56 PM
Man! Thats beepbeepbeepbeep good mileage I've never owned a dually (yet) but I have always heard that they wear a set of tires out pretty quickly. But that may be with a lot of tow miles on them too.
  #20 (permalink)
Old 01-19-2007, 08:14 PM
If you let a little more air outta the rears they wont wear like that in the middle.
