Stupid Question about Boost - Ford Powerstroke Diesel Forum
Old 04-11-2009, 09:31 PM
How can I tell if the motor gets too much boost (no guages)? Would a light come on, the truck run funny, etc? What damage can be done when this happens? WHat's the easiest way to cause over-boost (so I can prevent it)? Thanks.....
Old 04-11-2009, 09:39 PM
if you overboost it will throw the check engine light and you could blow your head gaskets but 7.3 heads are capable of 40 psi of boost so you should be fine is your truck stock
Old 04-12-2009, 05:23 AM
the only mods I have on it are the straight pipe (no muffler), Zoodad mod, and DIY intake
Old 04-12-2009, 05:38 AM
Yeah... no worries then.. you should be ok.. i thought the 7.3 Heads could hold about 55lbs??
Old 04-12-2009, 07:02 PM
yeah you should be fine. i have only heard 40 psi not positive though
