HELP fass or Air dog
What is better fass or air dog lift pump fuel systems for a 7.3 ford powerstroke i have a bully dog triple dog chip and 4 inch straight pipe into 6 inch stacks and a k&n cold air intake and what size pump would i need a stock to moderate or a moderate to extreme i have no clue about these at all and if it helps im getting a bigger intercooler and a bigger turbo down the road
you dont need either for your setup.... what you need to do is this (im sure others will agree)
dump the K&N and either do the DIY intake or a better filtering intake like the S&B get a custom burnt chip... its night and day diff from that BD stuff you have on... get yourself some good gauges.... maybe after you do all that then you can upgrade your pump... but even then your stock injectors wont be able to handle it.. your going to have to spend some good coin on injectors, pump, and turbo... not to mention that if you have a auto truck your going to need to do a fully built trans to handle the power... hope that helps if you have any questions please feel free to ask -Raul |
AIR DOG!!!!!
But before that get a new chip and get some gauges!! |
I agree planning on doing the Air Dog soon
i have auto meter gauges and what is wrong with the chip i got it has alot more power then some of the custom chips my buddys have and the k&n is def going out
either way even with that and stock injectors you dont really need a fuel system.... |
Raul is right unless you are running bigger injectors there is NOTHING to gain with a new fuel system. Between the two you mentioned Airdog would be my choiuce. Way to many problems with FASS, but you would be better off putting your cash elsewhere, OH and listen to what Raul is saying about chips, DP or TW will blow your Bull Puppy stuff out the door.
NCH |
my buddy has a dp and he has a 7.3 and he dose not have as much power as me and i just dnt get y everyone says bully dog is no good whenever everyone has them and let me ask u this then what would be ur choice of chip for a 7.3 that would give u the most power and tourqe out of a 7.3 powerstroke motor on a 2002
