Noise, P1298, and P0284
I was looking into a noise that sounded like a rod, but I understand that bad injectors can sound like a rod knock. The noise would be intermitint at idle.
Run a buzz and contribution test on a OTC Genesis. It returned theses codes. Buzz test P1298 Ignition Diagnostic Monitor Failure Contribution Test P0284 Cylinder # 8 contribution or Balance Fault My question is could the #8 injector be cause the noise and both faults? Thanks |
Could the black CPS be the fix
The truck runs fine. Could the Black CPS be the fix?
It's very possible. @ 1st, most people thought that if a grey CPS threw off 1 injector, it would also have to throw off a corresponding injector. So if your #8 was failing a contrib test, it would also have to throw off #3. Now people are finding when they replace the grey CPS with just #8 failing with a black one, the #8 failure is fixed. Most grey CPSs are known for making the #8 failing on & off.
