Help me decide on what to buy........ - Ford Powerstroke Diesel Forum
Old 04-02-2009, 03:41 AM
Question Help me decide on what to buy........
I only have the cash right now to buy one thing..........which should it be
99 F250 7.3 CC
4" turbo back exhaust for my truck OR Go open or use unrestricted flow muffler? Also best place with the best price? Which site is it??? I have seen Farmboys diesels, are their systems pretty good?
3 Pillar Gauges for my truck?
Ok which would you guys recomend, I know which way im leaning but would like to get others input. I am leaning towards the exhaust. What u guys think?
Old 04-02-2009, 03:49 AM
Pipe It
Old 04-02-2009, 04:07 AM
Gages that way you can base line the truck and note and see all the differences any mods make in the future. Plus if you get the gages and stumble on a chip for a good price you will be able to safely install it with out the extra cost of gages. You can always straight pipe it with a sawzall some pipe and some clamps which will be fine until you start pumping out mad power.
Old 04-02-2009, 12:30 PM
Send a message via MSN to Jesse.James
i would get guages and make it a straight pipe
Old 04-02-2009, 12:33 PM
i would probably go with the exhaust first. it'll sound good and lower your EGT's extending your turbo life. you shouldnt have to worry too much about monitoring your temps since the truck is stock. unless you already have a chip then i would do gauges first. just make sure you get gauges before you chip it.
Old 04-02-2009, 01:29 PM
Ok if i can scratch the money I want to do Exhaust and guages, Then save up for the chip. Some have said to do the muff del and get the guages and chip, would it not be to hot of egts with just a muff del. The down pipe is to small for the chip, is it not?
Old 04-02-2009, 01:45 PM
you can just straight pipe your truck using your existing factory pipe and you will be ok. although the temps will be higher, as long as you monitor them you will be ok. the bigger exhaust will help extend your turbo life because it will breath a lot better. i dont think it will be too hot with the stock exhaust as long as you dont just go wide open throttle all the time. if it was me i would probably save up and buy a combo kit from someone like raul at stealth auto. hes a sponsor on here. and i would also just straight pipe the truck and not worry about a muffler unless your worried about it being too loud or the local cops are writing tickets.
Old 04-02-2009, 01:51 PM
What to get a chip? Read here first!
heres the right up from someone with more knowledge them me
Old 04-02-2009, 02:11 PM
gus at farmboys has pretty good prices on his exhaust kits, we have put several on at the garage i work at we get all out diesel perf. parts through him his site is Welcome to Farmboys Diesel also have his number is you need just PM me if you would like
Old 04-02-2009, 02:16 PM
id do gauges for sure. then if there was enough money left id just strait pipe the stock exhaust
