Old 04-01-2009, 09:44 AM
blowinsmoke7.3 blowinsmoke7.3 is offline
How-to?
I need to take my door panels off, i think they are stuffed with dirt from ranch work with windows down over the years. I messed around with them for a little last night but it got dark before i could really get into it. Any hidden screws or anything i need to know about?
Thanks
Old 04-01-2009, 09:54 AM
Jake Jake is offline
<-----GTP38R
Freaking simple, i can have a door panel off in about 30 seconds. Pop the window/lock switch panel up, just lift up on the side closer to the rear of the truck. Take the screw out there, then pop the little light lens off near the bottom, and take the screw out that is in there, then lift up on the panel. Unscrew the lightbulb and set the panel to the side.
Old 04-01-2009, 09:57 AM
Never done it before dude. Im pretty sure i could of figured it out. Thanks for the help. Im hoping my super slow window speed and locks not working is due to dirt.
Plan on cleanin them up and doin a little lube job
Old 04-01-2009, 10:05 AM
benningtonr benningtonr is offline
Don't forget about the window sail.
Old 04-01-2009, 10:10 AM
Any body have any other ideas as to why my windows are super slow and door lokcs not working? I really dont think its the window motor. The two back ones are super fast, the two front ones are slower than molases...front 2 are always the ones down...
Old 04-01-2009, 10:13 AM
Don't know about window speed, but there is a fix for the door locks floating around. Very easy, for the most part. Just do a search for door actuator fix.
Here is one
Power Door Locks FIXED!!!! - Ford Truck Enthusiasts Forums
I am sure there are more, I did mine and love it
Old 04-01-2009, 10:14 AM
I see you have zoodad mod, why do you say usless now?
Old 04-01-2009, 10:20 AM
szyd szyd is offline
Cleaning and lubing should help.
The first time i took my pannel off I about craped it was the easiest panal i have ever removed.
Old 04-01-2009, 10:28 AM
<-----GTP38R
Cleanin them should help, mine used to be pretty slow, but not now.
Old 04-01-2009, 01:58 PM
Im hopin it will. Had the truck since 01 and they have never been cleaned
