Removing th wastegate line? - Ford Powerstroke Diesel Forum
Old 04-01-2009, 05:45 AM
What exactly does this do for our trucks.
Yesterday I removed the AIH, and replaced it with a 22m plug, and I also removed and caped the red line to the wastgate, not sure what that does for my truck.
Old 04-01-2009, 05:46 AM
It will allow you to have more boost. from what i've learned.
Old 04-01-2009, 05:53 AM
I have a stock turbo, what is the max boost i can safely have?
Yesterday I saw 28, close to 29
I am not makign a drag/race truck, just want to pull my racecar trailer with ease
Old 04-01-2009, 05:56 AM
Well i'd say thats probably close to pushing it.
Old 04-01-2009, 05:57 AM
Ok, that's what I thought as well, so I pluged the red line back in, now I here the turbo fluttering once in a while when i roll onto the gas hard.
Old 04-01-2009, 06:02 AM
wriott
Guest
Posts: n/a
On my 02 with the wastgate hooked up i am seeing 31 PSI, I havent had a chance to check it with the wastegate disconnected since i have installed my gauges. i might do that today.
Old 04-01-2009, 06:06 AM
Be careful doing this mod. The flutter you hear is probably your turbo surging.
Old 04-01-2009, 06:10 AM
I always wondered what people were talking about when they mentioned surging. Mine sounds like a bird taking off, albeit a very large bird, but it sounds like wings flapping, sort of, does that make any sense?
What do you mean by be careful, can you elaborate please.
Newbe, just reading and doing
Old 04-01-2009, 06:14 AM
Thats turbo surge. The stock turbo isn't happy or efficient above 25 psi. I talked with Jody a bit at the live tuning event he did up here and when I asked about running with the red line unplugged he said "leave it plugged in" before I could even finish No tuning I would run with it unhooked, but on a tuned truck its just so easy to build boost I don't see any reason to unhook it.
Old 04-01-2009, 06:19 AM
wriott
Guest
Posts: n/a
I have no problems hitting 31 PSI and holding it with the stock turbo. I have a wicked wheel comming. How much the surge and flutter will that get rid of and how much airflow or boost will it increase??
