Turbo Fluttering - Ford Powerstroke Diesel Forum
Old 04-01-2009, 05:28 AM
Turbo Fluttering
I made wholesale changes over the weekend, nothing that hasn't been on here forever though. But there are strange noises,
1st. Is a air discharge when the truck shifts
2nd. is a whooshing when in O/D applying gas and boost starts rising,
3rd. this doesn't happen everytime, but the turbo flutters when i roll into the gas fairly hard, and boost doesn't come up very fast, needle flutters as well starts, at around 10-15lbs.
Any Ideas Guys?
Old 04-01-2009, 05:38 AM
ive seen it alot on the edge programmers but nothing else sorry i cant help
Old 04-01-2009, 05:44 AM
Darn, I have a DP
Ok thanks, maybe another member has seen this one before.
Old 04-01-2009, 05:46 AM
I have some fluttering every now and then with my edge...time to upgrade
Old 04-01-2009, 05:51 AM
Time to upgrade what?
Turbo, tuner?
Thanks,
Ron
Old 04-01-2009, 06:27 AM
i know about the #2 problem. when i had my bully dog tow trial (only tuner i've ever had) i could push into it in overdrive but not let it down shift and it would start sucking LOTS of air. i'm pretty sure that was just the turbo spooling up and pulling in way more air than your stock air box could. you can also hear it too with a cold air intake
Old 04-01-2009, 06:31 AM
Ok, cool, that is what I was hoping it was, with the open airbox, do you hear a sound, like HP air releasing when your truck shifts and the rpms drop from say, 2500 to 1500?
Old 04-01-2009, 06:34 AM
yea. especially when i get into it. when your running higher rpms you have to suck enough air for that animal. but because of the engine you can't 'hear the air being sucked in. then when rpm's drop, there is no more engine noise and then you can hear the air sucking but by that point it's not needing to pull a lot so you hear it as the air slows down
Old 04-01-2009, 06:47 AM
The air during shifting is like,
You have heard a tractors air tanks purge right. When the compressor reaches 125lbs it stops and a big purge of air is released, sounds like that
Old 04-01-2009, 06:55 AM
yea i know what you mean. mine does that too.
