Old 01-14-2007, 05:26 PM
99dieselsmoke 99dieselsmoke is offline
max EGT???
im new to this site but ive had a 99 stroke for 4 years now. ive got and edge juice with attitude and edge evo downloader with a 5 inch exhaust. all i need to know is what is the max egt the stock turbo can handle?????? ive heard any wheres from 1270 to 1350. what is it??? i just installed my power adders 6 months ago but ive never had it above 1200 yet. a new turbo is in the works but id really like to know.
Old 01-14-2007, 05:34 PM
stump0331 stump0331 is offline
SNAFUSTUMP‹^›‹(•¿•)›‹^›
Tournaments Won: 1
1250 is a rule of thumb, but 1300 can be fit for a few seconds, if you havent seen 1200 yet you are safe
Old 01-14-2007, 05:35 PM
thanks for the help!
Old 01-14-2007, 05:37 PM
Tournaments Won: 1
that is pre turbo right?
Old 01-14-2007, 05:39 PM
yep. i dont like the idea of post turbo.
Old 01-14-2007, 05:42 PM
Tournaments Won: 1
yeah yur good then
Old 01-14-2007, 05:46 PM
owtcast owtcast is offline
Since you are the poster and you posted about pre or post, I'm not totally hijacking this thread....right? Are there others here that have an opinion about where the probe should be set. I've seen both but it seems you would obtain more accurate results with the probe right outside the exhaust ports in the manifold.
Old 01-14-2007, 05:52 PM
Marty Marty is offline
International Threat
Pre-Turbo is considered more accurate since a great amount of cooling can happen between the manifolds and the DP. The cooling is not linear so it's not as effective in determining egt's.
Pre-Turbo was VERY simple and took all of 30 min to drill, tap, mod, and wire up. I've never done post turbo install, so I can't comment about that.
1250* F is the maximum SUSTAINED EGT you want - you can run all day at or below that temperature. Short spurts (track/truck pulls) you can reach as high as 1300-1400 with no ill effects - then again you need to think about how your motor costs 10k to replace!
Old 01-14-2007, 07:09 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
There's a lot of trucks running high egt's for short times at the track, or sled pulling. If you build a truck and participate in multiple drags and pulls eventually you'll do a significant amount of damage. But if you wanna drag it a few times or pull it you aren't really going to hurt it.
Old 01-17-2007, 09:48 PM
99 7.3 99 7.3 is offline
off topic but, did u put it in w/ the motor out or still in the truck? if in the truck, how?!?!?! i've heard about leaving the truck running. how long of drill bit do u use, etc. i have one post turbo and am going to put one in pre turbo this spring. just wanna know how, easliest and BEST way to do it.
