  #11 (permalink)
Old 01-18-2007, 12:23 AM
BFD99 BFD99 is offline
Send a message via AIM to BFD99 Send a message via MSN to BFD99
ive seen 1500 for a few seconds, and i know someone who regularly sees 1800, but he has blown headgaskets, and is too lazy to get them fixed. He has other stuff to go on, but he wants to do it all at once.
  #12 (permalink)
Old 01-19-2007, 08:54 PM
straycat straycat is offline
99 7.3 Just go under the truck on the drivers side, look up at the manifold and you will see an open area. you want to drill close to the curve in the manifold. Get your gear ready, fire the truck up ,put some grease on the drill bit to catch the shavings, and when the bit goes through, the exaust will blow any other shavings out of the hole. shut the truck down, tap the hole, put a magnet on a nail with a 90 deg. bend on it, sweep it around inside the hole and your done. only takes a few minets, start to finish. Hope that helps---Gord.
  #13 (permalink)
Old 01-19-2007, 09:05 PM
BY THE WAY, ITS A 21/64 DRILL BIT AND A 1/8 NPT TAP. You can start off with a smaller bit for a pilot hole if you want.---Gord.
