ball joints - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-29-2009, 02:59 PM Thread Starter
ball joints
I just replaced the drivers side today, this is on an 02 4wd. i found uit weaird that the upper has no c clamp or anything.Its just pressed in. The lower also pressed but has a clamp?
this is normal?
thx
melmount is offline
post #2 of 5 Old 03-29-2009, 03:12 PM
not sure. how hard was it to put in? did you have a press, or just do it with hand tools?
19558077 is offline
post #3 of 5 Old 03-29-2009, 03:35 PM Thread Starter
ball joint tool with impact gun, i looked at the other side, no c clamp on the bottom of that. Its flat, no ridge coming thru long enough for a c clamp. Their is a groove in the new ball joint but its not long enough to stick thru the bottom frame part to allow me to install that. This is how the other side appears to be too. I am not really nervous. Just found it odd.
melmount is offline
post #4 of 5 Old 03-29-2009, 05:00 PM
460+'s Avatar
Its normal not to have a snap ring on the bottom of the upper ball joint.
99 F350 4x4 dually
7.3 w/K&N af
4" exh into 6" Aussies stacks
4"lift &35" tires
CC mod HP crossover line
Beans stage II 120hp injectors
D66 turbo
ITP regulated return
reburn on TS= 25,high idle,60,100,120,140hp
updated ecm (2000 model)
Dyno#'s 360hp and 965 ft lbs trq
460+ is offline
post #5 of 5 Old 03-30-2009, 07:08 AM
OUMX117's Avatar
Agreed. I just did all 4 of mine and the lowers were the only ones with the snap rings.
SOLD- 2007 F250 Harley 6.0
4.5" lift with 35x12.5-22 Toyo Open Country M/T
SCT X4 with Gearhead SRL, 8k Tow and Unlimited Tow, 4" TB Magnaflow
OUMX117 is offline
