Just bought my first PSD - Ford Powerstroke Diesel Forum
Old 03-27-2009, 01:37 PM
Hi all. I just purchased an 01 2WD F250. Its got almost 120k miles on it but runs very strong and shifts smooth. I just boight a fuel filter, and tranny filter and fluid. Is there anything else I should do as preventative maintance? Also is there any cheap or freebie mods to do to these trucks to make them run better? Thanks.
Old 03-27-2009, 02:04 PM
The Screwy HEUI
There will be a lot of contreversy on this mod, but there's the 10k & 5.6k resistor mods. Check it out in the 7.3 tech files under mods. While your @ changing the fuel/tranny filters, giver 'er an oil change too. Remember to drain your fuel bowl before you install the new fuel filter to get rid of any foreign material & water. There's a lever behind the fuel bowl for this. Also remember to put a drain pan underneath the front of the truck to catch the fuel. After you replace the filter, make sure the gasket for the cover is seated correctly, snug it up, & turn your key forward to prime the fuel bowl & you're set! Congrats on the new PSD! You'll love it!!!
Old 03-27-2009, 02:17 PM
Straight Pipe, 6637 air filter (DIY), gauges and chip
Old 03-27-2009, 02:22 PM
285,261,190
congrats on the new rig
Old 03-27-2009, 02:25 PM
welcome to the org
Old 03-27-2009, 08:19 PM
thanks guys.. can anyone tell me what rear end i have? at 70mph im a hair over 2k rpms. thanks
Old 03-27-2009, 08:59 PM
Send a message via AIM to 02lariat7.3
congrats on the new ride,im sure youll love it... ive had my first psd for about 3 months now,i love it! theres lots of good,knowledgeable people here,that will help you out with any questions you may have... if nothing else do the 6637 air cleaner mod, a exhaust is a good idea too, and a chip if youre wanting more power.
Old 03-28-2009, 08:57 AM
The Screwy HEUI
Chances are you've got 3.73s, but there's an ID tag inside the passenger door with a number for the rear axle. I would've posted the site that helps you look up what no. it is exactly, but it hasn't been working lately.
Old 03-28-2009, 09:05 AM
welcome to the org and congrats on the new truck!!!
Old 03-28-2009, 09:08 AM
Send a message via AIM to blowinsmoke4life
