"Gutted" Exhaust Elbow - Ford Powerstroke Diesel Forum
Old 03-26-2009, 08:14 PM
"Gutted" Turbo Outlet
i was wondering how to gut the Turbo Outlet. Maintain has a video how to gut the turbo pedistal but i cant find anything on how to gut the Turbo Outlet.
Old 03-26-2009, 08:54 PM
What exhaust elbow?
Old 03-26-2009, 10:16 PM
i meant gutted turbo outlet
i want to know can you make this with the stock one
Banks Power | 99-03 Ford - 7.3L Power Stroke>>Banks Power Elbow™ Assembly
Old 03-27-2009, 10:49 AM
It is easy. Just take the outer exhaust housing off. Then you will see the flapper in there riveted to a rod that hooks to the EBV. Grind off those rivets and pull that flapper out. Then use a 3/4" freeze plug to fill the hole. It is real simple and easy to do.
Old 03-28-2009, 04:34 PM
is there any gaskets need when you take apart the turbo? or ill i need is the pedistal
o-rings and new turbo bolts
Old 03-28-2009, 06:47 PM
You will just need the turbo and pedestal Orings. they are both the same Orings... You can get them at an international dealer if you have one nearby. That should be it. You don't need new turbo bolts just reuse them. No gaskets in the turbo...
Old 03-30-2009, 07:25 AM
Replacement O-rings for Diesel Engines has O-ring kits for just about everything on these trucks at great prices if you aren't in a hurry.
