unloaded tire pressures - Ford Powerstroke Diesel Forum
Old 03-19-2009, 11:22 AM
hey...what-r y'all running for tire pressures?
my CC f-350 calls for 50 front 80 rear..
you guys run 'em that high?
Old 03-19-2009, 11:25 AM
If I'm just cruisin around empty I run 60 all the way around.
Old 03-19-2009, 11:34 AM
I run 70 on my f-250 with BF all terrains.
Old 03-19-2009, 01:43 PM
i tried 50 in the front and it feels pretty sluggish/sloppy. -with all the motor on top of it, i can see why.
-the suggested pressure difference between the front and rear just seems to much. 80 in the rear for hauling heavy i'm sure but....jeeze.
mid 60ish all around seems reasonable i guess...
thanks!
Old 03-20-2009, 08:15 AM
I run max sidewall all the time.
Old 03-20-2009, 09:23 AM
75-80 all the way around all the time
Old 03-20-2009, 09:47 AM
Chapter Director
i run 50 in the front and 45 in the rear unloaded with 36x14.50 pj mudgrips
Old 03-20-2009, 09:55 AM
75 SUMMER, 60 WINTER
Old 03-20-2009, 12:22 PM
65 all around
Old 03-20-2009, 12:58 PM
Might also depend on what your tires are rated for. I think the sticker on the fuel door says 70 or so on mine, but the max PSI on the tires is like 65 so I run 65 all the way around. When I bought the toyos, I asked the dealer to make them what ever thier max presure was and he said they would only do what the manufacturer called for. Well they only put in 32psi.
