7.3l turbo specs
does anyone know the specs of a 7.3 factory turbo such as compressor size, A/R and anthing else will help.... thanks
kamron |
The only things I can really tell you is if you've got a '99.5-'03, you've got that redesigned compressor wheel that sucks. You can replace it with a Wicked Wheel or Banks Wheel. Your compressor inlet is 4".
early 99 turbo had a 1.10 compressor with the older style compressor wheel. I think it's a 60mm. The turbine housing is .84
Late 99 had a 1.10 or 1.0 compressor housing with a newer style compressor wheel (same size as the early 99) that surged. The turbine housing is a .84 also. |
Compressor inlet is 3" on a stock turbo. Ported shroud housing has a 4" inlet.
Are you absolutely sure about that?
Yes the inlet(intake) tube tapers down to 3 inch were it goes in the turbo
Aftermarket ATS Housing,38R, TN BB, H2E are 4 inch inlet |
I can tell ya from very recent experience , the stock inlet is 3" and most Aftermarket units are 4".
