DIFFS SIZE CONFUSION ??? - Ford Powerstroke Diesel Forum
Old 03-18-2009, 07:33 PM
Exclamation DIFFS SIZE CONFUSION ???
Hello Everyone,
I searched....and searched. I cant find info on the stock Diffs.. FRONT & BACK.
My truck is a 99 f-250 super duty, reg cab, long box, 4x4, manual
I assume i got a tow package as i got a trans cooler...
I think I have 3.73's... as per ford... that is all they could tell me ???
I looked at the door tag, tried to find a VIN decoder, no tags or what so ever on the diffs ...the works...
i got people telling i got rockwells... sterlings... dana 40,60,70,80 ect...
Any help would really appreciated.
Old 03-18-2009, 07:35 PM
Cynic
If you have f250, you have a sterling 10.5 rear end. I would need the door code to tell you the ratio.
The front end should be a dana 60.
Old 03-18-2009, 07:36 PM
Your rear axle is a 10.5 steerling rear end. THe front can be a dana 50 or 60. There is probably a tag on the diff cover that will give you info that a drivetrain shop can make usefull.
Originally Posted by builtnotbought View Post
Hello Everyone,
should have sticker on front diff both of mine does
Old 03-18-2009, 07:37 PM
Cant the front be a 50? im pretty sure a read a petersons 4X4 magazine awhile back that said it can be either.
Old 03-18-2009, 07:40 PM
Cynic
Most of the superduty's I've seen have d60's. The OBS f250's had d50's.
Old 03-18-2009, 07:51 PM
Cynic
?? one is the front, the other is the rear. Both are fairly tough axles.
Old 03-18-2009, 07:53 PM
Exclamation
I believe the Dana 60 is 9.75"
Sterling is a 10.5" ring gear is just made by a different company and is roughly equivalent to Dana 70??
Right ?
Old 03-18-2009, 07:54 PM
Cynic
No clue on that.
Old 03-18-2009, 07:57 PM
Cynic
I do know that whoever told you that you have rockwell's... has never seen them.
