Coolant??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-17-2009, 05:12 PM Thread Starter
deere4440's Avatar
Coolant???
Well i just noticed that my water pump is starting to leak, so i got a project to do in the near future. So i was curious what is the proper way of flushing the system completely out, and what kinda of coolant would you recommend me putting back into it. Oh and what is the precedure for taking the water pump off? Any help would be greatly appericated!
2002 F-350 CC SB 7.3
MBRP 4 in straight pipe
AIS Intake
Foil Delete
Factory Tech Valve Body
203 Thermostat
Fog Light Mod
6k HID's from DDM
TOTALED!! 1/6/2009
2003 F-250, 7.3 FX4
deere4440 is offline
post #2 of 7 Old 03-17-2009, 07:35 PM
RadarRider's Avatar
The waterpump's a pretty simple operation. Just take a good look @ it & you should be able to figure it out easily. As far as type of coolant, just stick with the green stuff. Prestone's a pretty good company.
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #3 of 7 Old 03-18-2009, 02:49 AM Thread Starter
deere4440's Avatar
AIS Intake
Foil Delete
203 Thermostat
Fog Light Mod
6k HID's from DDM
TOTALED!! 1/6/2009
2003 F-250, 7.3 FX4
post #4 of 7 Old 03-18-2009, 08:47 AM
After you complete a good flush of the coolant system and replace your water pump you may also want to consider installing a coolant filter. The 7.3’s are known for having a lot of sand that remains in the block after the casting process. This sand can continue to “weep” out of the pours of the block for years even after flushing the system. The sand floating around in the system can cause accelerated wear on the water pump as well as the rest of your cooling system. Just something to consider. As far as the coolant goes, You will be able to find waaaaay too many post’s that talk about the color/type/brand of coolant to use. Some of the 2002 trucks produced early in the production run came equipped with “green” coolant. The 2002 trucks produced later in the production run came equipped with “gold” coolant. If the truck came with green, use green. If the truck came with gold, use gold. You also have the option of switching to a true heavy duty diesel spec coolant. Again, you will be able to find lots of information (and tons of passionate opinions) about the type of coolant available/recommended for your 7.3. Good luck with your project.
2002 7.3 F350 CCLB
4" Turbo-back Pinnacle (Jerry Jardine) Exhaust
Racor 2 Micron / 90 G.P.H. Fuel Filter
Baldwin BT111 External Trans Filter
OilGuard EPS-20 Oil Bypass Filter
Baldwin B5134 Coolant Filter
Dual External Trans Coolers
DieselSite 203 Thermostat
D.I.Y. Nappa 6637 Intake
SuperChips 1705
Bilstein Shocks
Zoodad Mod
HPX Line
vetmxrider is offline
post #5 of 7 Old 03-18-2009, 08:53 AM
ABoyAndHisToys's Avatar
Send a message via AIM to ABoyAndHisToys
I would replace it with the same color that came out. Also a filter is a great idea.
2001 CC Long Bed Fat A$$
New Heart w/Forged Rods @ 108,000miles (Damn PMR's).... with some goodies on it
Brandon
ABoyAndHisToys is offline
post #6 of 7 Old 03-18-2009, 04:07 PM
I have tried to paste a link below that will take you to another post that discusses coolant filters. If you look at my post about 4 or 5 down from the top you will see a couple of pics and the links to take you a site that sells the filter base and the filter. You can also buy the complete set-up with all the fittings, clamps, hose, filter base, bracket and spin-on filter from Dieselsite.com
anyone know how make a coolant filter
2002 7.3 F350 CCLB
SuperChips 1705
Bilstein Shocks
Zoodad Mod
HPX Line
post #7 of 7 Old 03-23-2009, 03:54 PM Thread Starter
deere4440's Avatar
Ok well that kinda helps me out. Any other help out there???
AIS Intake
Foil Delete
203 Thermostat
Fog Light Mod
6k HID's from DDM
TOTALED!! 1/6/2009
2003 F-250, 7.3 FX4
