Looking at buying a 2001 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-15-2009, 04:53 PM Thread Starter
Brfootball45's Avatar
Send a message via AIM to Brfootball45
Hey guys looking at a 2001 ford f-350 crew cab , the truck has 78,000 miles on it, but the only problem is the guy said a seal needs to be replaced in the turbo and a clock spring? he said it smokes a little. is this a serious issue?
Brfootball45 is offline
post #2 of 9 Old 03-15-2009, 04:55 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Whats a clock spring?
Tubo seals are not hard!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 9 Old 03-15-2009, 04:57 PM
wonder's Avatar
A clock spring in a winding of wires in the steering colum for your horn or cruise
wonder is offline
post #4 of 9 Old 03-15-2009, 05:07 PM Thread Starter
so is it a serious issue, do you think it will be worth it?
post #5 of 9 Old 03-15-2009, 05:13 PM
wonder's Avatar
there not usually that hard to change. you have to pull the steering wheel off
wonder is offline
post #6 of 9 Old 03-15-2009, 05:13 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
Depends on what he wants for it. Low miles on a 7.3 is nice, but why is the turbo shot? Is there dust in the intake? Check for that. If there is a ton of dust don't buy it, cause even if you replace the turbo there might be cylinder wall damage from sucking in dust.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #7 of 9 Old 03-15-2009, 05:30 PM Thread Starter
ya all he had told me was that the turbo seals need to be replaced because it smokes a little. could this just be from normal wear and tear or ? also the truck only has 78000 miles on it
post #8 of 9 Old 03-15-2009, 05:33 PM
I guess it could be from normal wear, but i would check the intake for dust like i said.
Diesel Dan
post #9 of 9 Old 03-15-2009, 05:38 PM Thread Starter
alright will do!
