suggestions please
i have a 99 f-350 that is turbo surging really bad. as well as the pedistel is leakin oil out of the plunger. basically my truck is running really bad. it also has started running like its only got half the cylenders fireing. i had the injectors checked and all of them are perfectly fine. i thought i had a compression issue. can someone let me know what my problem is due to it running really really rough. almost like its mis-fireing. please help me.......
p.s. with the pedistal leaking oil out of the plunger and it leaks onto the right side of the block could that also cause my truck to run rough as hell???
Reason: update
