Lockers - Front & Rear - What's good? - Ford Powerstroke Diesel Forum
Old 03-14-2009, 08:14 PM
I'm wanting to put real lockers in the front and rear axles. Which ones are good? Which ones should I stay away from? I have 37" Tires right now, but may lift the truck more in the future for some 40's. Not sure if that makes a difference or not, but i'll be wanting to do a gear swap when I put the lockers in. I have 3.73 right now, should I go with 4.10 or 4.56?
TIA!
Old 03-14-2009, 08:18 PM
I would go with 4.56's for a gear swap with 40's....
Old 03-14-2009, 08:29 PM
As far as lockers, I would go with a Detroit or ARB. Mostly depending on your usage. ARB's are VERY nice in the front and can be handy in the rear.
-Aaron
Old 03-16-2009, 09:31 PM
-Aaron
usage is generally for muddy situations. I was noticing the one wheel peel this weekend. i'll be doing gears fairly soon so i might as well throw some lockers in there too. On the other hand.... it doesn't see mud often. Just when i'm feeling froggy.
Old 03-16-2009, 09:39 PM
4.56 for gears.... if you can afford to put ARB's front and rear i would do that if not i would do a Detroit rear locker and ARB for the front
Old 03-16-2009, 09:41 PM
How much are ARB's? What are the specifics i'm looking for in shopping? Pretty sure the rear is a Dana 60, which spline? What's the front? Spline?
Can I put detroits front & rear?
ARBs are awesome and then you will also have air to run whatever else you want
Old 03-16-2009, 09:43 PM
I plan on putting train horns on it pretty soon and getting a pump & tank big enough i can air up quad tires and such while we're out riding for the week or weekend. Would that type of air system work?
Old 03-16-2009, 09:52 PM
Yes, my cousin has them on the fronts of his jeep and he has a air hose running from it with a quick connect
Old 03-16-2009, 09:53 PM
your rear is a ford 10.5 or 10.25 which uses the same locker.. your front is either a dana 50 or dana 60
ARB's are about 900 just for the locker detroits are around 750ish and does not require the air compressor... but you def want a selectable locker for the front which is the reason i suggest the ARB
