7 pin hook up
Im sure you guys already know and Im probably the only jack a@# who didnt but after alot of research found out. If you use your 7 pin and are not getting 12Volts to the power outlet (black wire) you need to install a relay in the little box under your hood beside the bigger fuse box. Just though I would share in case anyone else is trying to figure it out. Please take it easy on me!
Well I'm not gonna dog ya, cuz I didn't know anything about that. Thanks for the info!
did you install the 2 maxi fuses in the emgine compartment box? They are missing from the factory, hope thats what you are looking for and not a relay.
) but yeah its the little box that doesnt have nothing in it but two slots for relays because you have two smaller boxes beside the fuse box.
7-pin
Depending on your trailer wiring requirements you can use the relay to provide 12volts to the black wire with the ignition switch on. My requirements dictate a constant 12 volts to the trailer connection at all times for trailer interior lighting, so I installed a jumper in the relay spot. I keep the relay in the console for accommodating friends trailers demanding ignition on 12 volts. Either way short protection is provided by the maxi fuse.
