blow off - Ford Powerstroke Diesel Forum
Old 03-12-2009, 03:30 AM
blow off
okay first off dont bash me saying diesles dont need blow offs, all i need to know is where do i hook the vaccum line coming off the blow off valve? Thanks
Old 03-12-2009, 07:06 AM
The Screwy HEUI
What do you have for a BOV? Where do you have it installed?
Old 03-12-2009, 07:45 AM
You dont have anywhere to hook a vac line... Diesel's dont make vacumn...
Old 03-12-2009, 12:06 PM
what's the brand and part number of the BOV so we can see how it works?
Old 03-13-2009, 06:43 AM
Unless you have an aftermarket turbo you don't have a blow-off valve. What you do have is a wastegate, which isn't the same thing but somewhat similar. And as Joe said, you don't have a vacuum line either, it's a pressure line. Simple to hook up- look at the inlet of your turbo. Just behind that almost against the firewall you'll see a gold canister bolted to the turbo- that's the wastegate. It should have a nipple on it pointing toward the driver's side of the truck.. rub the nipp (oops wrong forum!) I mean hook the red line up to this nipple.
Old 03-13-2009, 06:47 AM
Send a message via AIM to dana60axle
you have to get a bov for a diesel most gas ones wolnt hold the pressure and work a little different you can use one on a truck twin turbo ed or not you get the same gains from it and it sounds awesome ive wanted to do one but there like 500 dollars
Old 03-13-2009, 06:49 AM
They have a vacuum pump for the hubs.
Old 03-13-2009, 06:55 AM
they do it also is for the heat and ac with out it the vents would not change but in order to rele tell you we would have to know what bov you are using
Old 03-13-2009, 09:54 AM
The vac pump is needed because the engine won't make vacuum like a gasser will.
Old 03-13-2009, 09:56 AM
Your very right, they have a vacumn PUMP, they do not make vacumn like a gas rig does. Thats why the OBS had a vac pump for the brake booster as well.
A normal blow off valve is not needed on a diesel.
