Vibration.....Help!!!! - Ford Powerstroke Diesel Forum
post #1 of 31 Old 03-11-2009, 07:17 PM Thread Starter
99BEIGEPOWERSTROKE's Avatar
Ok heres the deal. I got a 99 F250 and I got a vibration that feels like its under my feet on drivers side. I have recently replaced the hub, ball joints, and outer axle shaft on the passenger side as I had abroken ball joint and this stuff on the drivers side seems fine and tight. I can feel it in 4x4 or 4x2. Is there anything in the front end that turns and would cause a vibration when the truck is in 2 wheel drive and the hubs are unlooked? Does the front driveshaft turn when the hubs are unlocked? The front drive shaft does feel a little loose so I thought maybe a u joint but I wouldnt think it would make noise and vibrate in 2 wheel drive unless it turns. What else in the front end?
My other option is the rear drive shaft u joints but they feel tight. What else could I be looking for? I rotated the tires and it didnt seem to make much of a difference but im thinking of getting them rebalanced. Any other ideas to look for to get this annoying vibration fixed?
One more thing to help. When I drive and it is in gear the vibration is there when accelerating or when just cruising but if I take the truck out of gear and just let it coast the vibration doesnt seem to be there near as bad.
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS 175/146 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
99BEIGEPOWERSTROKE is offline
post #2 of 31 Old 03-11-2009, 07:25 PM
strokerguy's Avatar
i would change the u joints and see if it goes away JMO
99 f350 reg cab 4x4 zf6 speed stock for now
strokerguy is offline
post #3 of 31 Old 03-11-2009, 08:44 PM
mudslinger's Avatar
mine does the same thing as of two of my buddies all 99 and one 00 oen of them works for CAT and he said he cant find anything wrong.
1999 F-350 SRW X-Cab Long Bed 6-Speed
straight pipped in to a 6 inch tip other then stock
mudslinger is offline
post #4 of 31 Old 03-11-2009, 08:49 PM
RJM06590's Avatar
mine does it but thats from the tires bein unbalanced. It only does it from 40 to 55
Rob
95 Fummins Puller "keep Em Cummin"
RJM06590 is offline
post #5 of 31 Old 03-11-2009, 08:59 PM
Typically if you have a vibration that changes with speed only under accel, and is mostly gone when you under a no load coast condition then you should remove the drive shaft and feel the U-joints for roughness or stiffness, you can not find a bad U-joint with the shaft installed unless it is extremely bad, as in way beyond time to be changed. Good luck. Hope this helped.
no1fordnut is offline
post #6 of 31 Old 03-12-2009, 06:33 PM Thread Starter
I gotta check u joints. Would it just be the rear u joints to check since it vibrates in 2wd or 4wd and in 2wd the frontdriveshaft dont spin right? Any other ideas on what to check?
6 SPEED
SWAMPS TUNING
6" AUSSIE STACKS
VAN TURBO
4" SUSPENSION LIFT
COWL HOOD
post #7 of 31 Old 03-12-2009, 06:39 PM
spdjnky_42's Avatar
Send a message via Yahoo to spdjnky_42
Ive heard that these are hard to tow because of the fact that the front driveshaft turns all the time (except neutral?) However if your vibe gets worse under load in 2wd then its probably just the rear. However, I have a place that only charges $30 a u joint (p&l) so if I were having the problem, which I am by the way, then I would just replace all and be done at once.
spdjnky_42 is offline
post #8 of 31 Old 03-12-2009, 07:35 PM
RJM06590's Avatar
front driveshaft only turns when its in 4 wheel i have mine disconnected right now and it doesn turn
Rob
RJM06590 is offline
post #9 of 31 Old 03-13-2009, 06:24 AM Thread Starter
Ok I didnt think the front driveshaft turned in 2wd. I will have to check rear driveshaft and u joints. One more thing I have noticed is when I brake it causes the truck to shake and vibrate a little. Would that be caused by the rear driveshaft and u joints as well or do I have another problem in my brakes?
6 SPEED
SWAMPS TUNING
6" AUSSIE STACKS
VAN TURBO
4" SUSPENSION LIFT
COWL HOOD
post #10 of 31 Old 03-13-2009, 06:30 AM
Tony V's Avatar
Ok i've got the same problem and I've been changing parts like crazy. Ok I would bet its not your driveshaft if you grab it and its tight. To check if it is your front driveshaft just take it out and drive your truck. Today im going to check my needle bearings.
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
