my cruise control doesn't work help???
well my cruise doen't work on my 00 f-250. first off no burn't fuses and the lights on the steering wheel work. you push the on button and set speed and nothing not even the light in the dash. help please.
scott |
not sure about your truck...but on mine there is a black box looking sensor on the side of the tranny. it may need replaced. do your back up lights work? i need to replace mine because my back up lights dont work but was told it controls both...my cruise will work one day and the next it dont...but my back up lights never work. hope this fixes it.
nope not it
well no burnt fuses and no light in ur dash u either have a wiring issue or a faulty combo switch. Check for power at the switch if you get voltage I would replace the combo switch... Maybe see if you have faults b4 tryin that though...
Replace the bulbs in your third brake light (the one one the back of the cab)
Or make sure it works. also if you have l.e.d after market light bulbs, the cruise won't work either. |
There is a sensor on your hydro boost unit, if it comes unplugged your cruise control wont work. I accidentally broke the clip part to where it wouldnt stay clicked in while i was installing injectors, etc. I found this because after the install, my cruise wouldnt work either, zip tied it back on and it worked again. Just my experience though lol.
If you have a manual tranny, check the CPP - clutch pedal position switch.
yeah i had this prob 4 ever before i was on here of course could not figure out why my cc would not work. Long story short went to dealer 25min and 40 bucks later all it was is a plug that had came unhooked
I went and checked and my third was out replaced it and still nothing from the CC |
