Can i do this? - Ford Powerstroke Diesel Forum
Old 03-11-2009, 08:24 AM
Can i do this?
A few weeks back i pulled my intercooler pipe back off to finish polishing it up after doing the foil delete. I noticed that a bolt had rubbed a hole about the size of a dime through my IC pipe.
We've got a 94 F-450 that gets driven maybe a handfull or so times a year. Will the IC pipe off of it fit on my truck sorry if its a stupid question just looking for a fix.
What should my boost numbers be on my truck if i didnt have the hole in my IC pipe? Right now crusing i barely see 4lbs, uphill with my foot layed into it i can barely hit 12-15. Im sure this is due to the hole.
Old 03-11-2009, 08:30 AM
Send a message via Yahoo to Big_Stroker
well i dont think the 94 will have an intercooler. but that is why your boost is low... you should have able to can it from a stop and see 18 - 21 psi no problem
Old 03-11-2009, 08:41 AM
No it has an IC. I was just guessing the year, its my grandfathers truck..maybe its more like a 97...
Old 03-11-2009, 08:48 AM
it might work... didnt know the OBS trucks has intercoolers
Old 03-11-2009, 08:55 AM
Just hit the junkyard to find one. I was just there over the weekend and there were intercooler tubes all over the place...
Old 03-11-2009, 09:00 AM
Im not to familiar with the obs rigs but im pretty sure they have intercoolers
at least the later year models Maybe we can get an OBS guy in here
Old 03-11-2009, 09:01 AM
Stock OBS's dont have intercoolers.
Old 03-11-2009, 09:02 AM
I don't think they will work. Typically the obs guys are buying our stuff to convert their trucks.
Just go to a local junkyard or call them and check them out. You might just get one for 10-20 bucks.
Old 03-11-2009, 09:06 AM
also u chance somethin gettin into ic tube, turbo unlikely but possible i would get it fixed drill the hole out round and find a bolt that will thread into it
Old 03-11-2009, 09:10 AM
i wonder if i could take it to a welding shop and have them weld it closed and grind it smooth?
