Leveling kit problems! - Ford Powerstroke Diesel Forum
post #1 of 23 Old 03-08-2009, 04:58 PM Thread Starter
bigbigrdg's Avatar
Ok I just finished installing my leveling kit that i bought off ebay. It is made by maxx-lift. I un bolted the lower end of the sway bar and put the leveling block and ubolts together and couldnt get the sway bar to match up with the hole again. Its off by about an inch...Do i need to get a bigger one? Please help!
2000 F-350 Reg. Cab
4" Banks Monster Exhaust
Foil Delete,Zoodad
Rancho 9000xl Shocks
DIY Intake
Smoked Recon LED Cab Lights
285/75/16 Nitto Terra Grappler, Black Rims
2005 Harley Headlights
08 Tow Mirrors
07 Black Grill w/International Emblem
6.0 Tranny Cooler
JW Valve Body
133k Miles
bigbigrdg is offline
post #2 of 23 Old 03-08-2009, 05:07 PM
You may have to flip the sway bar brackets from the inside of the frame to the bottom of the frame. Thats what I had to do
rock hardson is offline
post #3 of 23 Old 03-08-2009, 05:32 PM
Let us know how it works out. Oh yeah, one more thing:
post #4 of 23 Old 03-08-2009, 05:43 PM
hoosier golfer's Avatar
2X on flipping the brackets! That ought to work for ya.. I got the same lift on my truck but I had no problems!! But I also didn't take my sway bar loose either
~Adam~
2006 King Ranch
~Other Toys~ 05 Ranger 520VX Commanche 225 HP VMAX HPDI !!
~Lots Of Guns & Custom Knives~
hoosier golfer is offline
post #5 of 23 Old 03-09-2009, 02:29 AM
Powerstroke Junkie
NCHornet's Avatar
You need to use a adjustable or reloactable trac bar bracket. I prefer the adjustable trac bar. Otherwise you axle is 5/8 to 3/4" off center.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 23 Old 03-09-2009, 03:41 AM
Big_Stroker's Avatar
Send a message via Yahoo to Big_Stroker
NCH
Adjustable trac bar is the best way to go with this.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Live Tuned By Matt @ Gearhead Automotive
516hp and 1121tq - 4/24/10
Big_Stroker is offline
post #7 of 23 Old 03-09-2009, 12:09 PM
Let's go B's!!!!
Southpaw's Avatar
Feedback Score: 5 reviews
You guys are talking about two different things.
The op says swaybar, but it sounds like he means tracbar...
Either way you're covered. If it is the swaybar endlinks, you can flip the mounting brackets. Thats what I did. If it is the tracbar, I have a tracbar relocation bracket on mine and have no problems yet, although an adjustable tracbar is preffered. pricey though IMO
Chris
2002 Crew Cab Long Bed
4" BDS, 35x13.50 Cooper STT on 20x10 Black Rockstars, and other stuff.....310,000 miles and counting...
2 Thessalonians 3 v.6-15
Southpaw is offline
post #8 of 23 Old 03-09-2009, 07:25 PM Thread Starter
bigbigrdg's Avatar
ok yea i think i goofed, I think i am talking about the track bar, i feel like dink now haha. I will have to take a picture tomorrow and then someone may be able to tell me what i need to do. thanks for all the help guys!
2000 F-350 Reg. Cab
Foil Delete,Zoodad
DIY Intake
08 Tow Mirrors
6.0 Tranny Cooler
JW Valve Body
133k Miles
post #9 of 23 Old 03-09-2009, 07:53 PM
BryanH's Avatar
NCH
Well said, If it is still tough after getting the adjustable trac bar ends, Loosen the upper trac bar bracket, Bolt the trac bar the the upper bracket, Then tighten the bracket back up
546K 7.3L Hauler
Central Texas Hotshots
BryanH is offline
post #10 of 23 Old 03-11-2009, 03:47 PM Thread Starter
bigbigrdg's Avatar
I finally got around to taking pictures...You can see where the bolt is missing. I dont know exactly what this is even called? What can I do to get it back in line? thanks guys!
2000 F-350 Reg. Cab
Foil Delete,Zoodad
DIY Intake
08 Tow Mirrors
6.0 Tranny Cooler
JW Valve Body
133k Miles
