Front end noise - Ford Powerstroke Diesel Forum
Old 03-08-2009, 03:29 PM
Front end noise
My truck is making a rattle/clunk over bumps coming from the front end.
I checked the ball joints, sway bar end links and bushings, tie rods wheel bearings and U-joints and every thing is tight.
Any ideas on what the noise could be?
Old 03-08-2009, 03:31 PM
Once you go black......
Send a message via MSN to CanadianDiesel
stabilizer link? Mine was making a noise and clunk, had it changed and its fine now.
Old 03-08-2009, 03:36 PM
How many miles on it? Mine was the same and even though it "seemed" like the ball joints were ok..they were toast. The uppers were worse than the lowers. FYI - mine has 101K on it, and its 4wd.
Old 03-08-2009, 05:00 PM
142k but they have been replaced and I checked them pretty good no play at all.
Old 03-08-2009, 07:06 PM
might be the front hubs?
Old 03-08-2009, 07:12 PM
thats what i was thinking. lock the hubs but leave the t case in 2wd and see if it still does it
Old 03-09-2009, 02:23 AM
Powerstroke Junkie
I just finally fixed my popping in the front end. My track bar was loose. I mean just barely loose, all it took was 1/2 turn of the 1 1/4 bolt to make it go away. See if the washer with the finger on it is loose on the back side of the mounting bolt. Then wrench on that net with all you got!!
NCH
Old 03-09-2009, 03:49 PM
do you feel it right under your feet?
Old 03-09-2009, 04:00 PM
looked at it closer today. the right lower shock bushing is shot and causing the rattle. thanks for your help guys
Old 03-09-2009, 04:17 PM
may i ask how you checked the shock bushings. i cannot tell if its the shock bushings or the sway bar bushings.
i checked everything else.
also could you feel the clunking under your feet?
