New turbo is here!! - Ford Powerstroke Diesel Forum
Old 03-03-2009, 09:39 AM
New turbo is here!!
Got my new GT38R in today! UPS guy made a comment about how I'm "getting to be a regular." Haha, I told him not to get used to it, I only have so much money.
Anyway, I of course had to take it out and check it out since I need the rest of the parts before I put it in and now I have a question. There should be a little bit of play in the compressor and turbine right? I can actually see it move side to side if I press it back an forth with my finger, but I would assume that as hot as all that stuff must get it will tighten up as it heats up, and that is normal right? It doesn't touch the sides, so I guess it will be good. I just get real careful and tend to worry too much when I am messing with $1600+. Thanks.
-Aaron
Old 03-03-2009, 09:42 AM
Did you buy it new?
Old 03-03-2009, 10:01 AM
Yep, that is why I figure I am just concerned for no reason....Still had to check though.
-Aaron
Old 03-03-2009, 10:08 AM
There will be a little shaft play since there isn't oil in the bearings.
Old 03-03-2009, 10:09 AM
Congrats on the new toy dude!
say no to rolling coal
I think the housing should be a little loose when it gets shipped to you. You need to be able to adjust it once you install it to line up with all the plumbing and then you tighten it down.
Old 03-03-2009, 10:12 AM
Ole White
Congrats man ! !
Old 03-03-2009, 10:32 AM
DANG! wish i could afford one of those bad lads!
Old 03-03-2009, 10:41 AM
do you want to sell your old one?
Old 03-03-2009, 01:13 PM
Layson is right. There will be a little play due to no oil in the bearings. If you pour a little oil in the feed and rotate the turbo it should tighten it up quite a bit.
If only I didn't waste my money on a new stock turbo and ATS housing...I want a 38r.
