help please truck wont start - Ford Powerstroke Diesel Forum
Old 03-01-2009, 07:53 PM
i have a 2002 f-250 powerstroke and its got 85k miles and for some reason when i go to start it in around 50 degree F weather and less it wont start im assuming the glow plugs need to be replaced. any suggestions?
Old 03-01-2009, 07:59 PM
The Screwy HEUI
Possibly GPs or the GPR. Also have you had the CPS recall done yet?
Old 03-01-2009, 08:02 PM
Send a message via AIM to harrys91rs
+1 for possibly gpr.
Here's the tech files on glow plugs/ relay and how to test them:
Glow Plug / AIH Relay locations
Old 03-01-2009, 08:03 PM
yea im not to familiar with powerstrokes so what are GPR's and CPS
Old 03-01-2009, 08:05 PM
The Screwy HEUI
GPR= Glow Plug Relay. If you look in the 7.3 tech files, there's a thread that shows you where it is on top of your engine. The CPS is your Cam Position Sensor. I figured since your truck has such low miles, it might not have been replaced yet. Your CPS is just above your crank pulley, has a wiring harness running to it, & is held in with 1, 10mm bolt. There's a recall on these & you can get a new one from Ford for free if it hasn't been done yet. Since your truck won't start, you might have to go to Ford or IH & buy one.
Old 03-01-2009, 08:24 PM
damn how much do you think eight new gp's are?
Old 03-01-2009, 09:25 PM
The Screwy HEUI
I'm not 100% sure, but they're cheaper than spark plugs.
