Hit 1500 egts - Ford Powerstroke Diesel Forum
Old 03-01-2009, 02:53 PM
Hit 1500 egts
Testing out new chip to see how it went. Hit 27 pounds of boost and 1500 egts at 90mph. EGT probe installed in the y-pipe where the 2 up pipes meet. Am I still safe or should I avoid exceeding 1250?
Old 03-01-2009, 02:56 PM
dude. thats too high. askin for trouble there fella. lol. especially if your in the y pipe. chances are your EGTs are even higher right at the exhaust port where the probe is spost to be. Be careful man.
Old 03-01-2009, 02:58 PM
Oh my....The Y pipe sounds a little far back from the head. Everything I have heard says as closer to the engine so the exhaust doesn't have a chance to cool down. If you hit 15 at the Y, then you can be sure it was bleepin hot at the valve. I wish you the best.
Old 03-01-2009, 02:59 PM
i would move the probe to see what it realy is make sure you are care
Old 03-01-2009, 03:01 PM
Ya.. i was thinking there would be good because it would give me a combined temp reading.
Old 03-01-2009, 03:09 PM
its prob close, but not exact. I wouldnt take it above 1200 with your guage set up now. should be ok. anything above 1450 for any length of time will melt stuff.
Old 03-01-2009, 03:10 PM
Geez, ya thats hot considering its already cooled some by the time it gets there!
Old 03-01-2009, 03:23 PM
Well it wasnt there for long. Went from 0 - 90 just to test out the extreme tune. And how accurate can having a probe on only one side be? I have heard temps can be different on each side so unless you have a probe for each side, i just figured that would be the next best place for combined readings. I guess I'll have to be a little more carefull. So dont exceed 1400 for even short bursts. Thanks
Old 03-01-2009, 03:25 PM
I ran one on each side in my 94!
Old 03-01-2009, 03:27 PM
what tunes are you running? it doesnt sound like they are very well written...
