2 stroke oil in diesel fuel
Hey, has anyone ever herd of adding 2 stroke oil to your diesel fuel? If so why?
yea people do it because is quites the injectors down also its easier on the motor
any side effects? white smoke, clogged injectors? Why not? If its easier on the motor sounds good to me. I use Power Service in mine, maybe a little 2 cycle also would be good?
Doesn't diesel fuel additive do the same thing?
not shure on the side effects i dont think so but some one will chime in and clear it up for you
I run it is mine and the sound diff. is very noticeable. Make sure you run the tc-w3 mix one oz. per gallon of fuel.
It helps lube the top end of moter. ULSD is not as lubricating as old Diesel. If you use 2cyl I think the most important thing to look for is that it is an ashless formula?
Cheap ashless 2 stroke is the best bang for the buck. Getting fancy expensive oils isnt going to make a drastic difference for the price.
Powerservice is good for several things but not very good as a lubricity additive. I stopped using powerservice and began using 2-stroke oil from walmart about 250 gallons ago and it was immediately better in terms of engine noise with the 2-stroke.
Do it. You'll notice within the first tank. 1 oz per gallon. |
What does the ashless do over the non ashless!
