quick turbo and trans shift general question - Ford Powerstroke Diesel Forum
Old 02-25-2009, 08:58 AM
Hi Everyone, Two questions.
1- Do I have it correct that when the turbo starts occasional chirping, it's starting to die?
2- Ever cense the trans was done, 90% of the time, the overdrive when it engages, the engine "flairs up" a bit. Like it's having trouble engaging? Sometime, goes right in. Happens under acceleration, and easy steady speed. If I let off the throttle at the right time, it engages ok without the flaring. Not sure what's up, and if it's going to cause mechanical problems down the road.
