Old 01-04-2007, 10:42 PM
dukey_78 dukey_78 is offline
10k mod
Would u be able to tell a difference with the 10k mod if u have a programmer??
Old 01-04-2007, 11:19 PM
Marty Marty is offline
International Threat
It's not the best idea to 'stack' them because your programmer is already adjusting icp in most cases.
Old 01-08-2007, 12:55 PM
although i have the programmer it is still a dog off the line it doesnt start to go until i am running like 5 or 10 mph i want instant power
Old 01-08-2007, 01:06 PM
What chip are you running?
Old 01-08-2007, 01:08 PM
i am running a programmer and it is the edge evolution and i know it is working cause man it runs a 100 times better than b4
Old 01-08-2007, 02:53 PM
mako314 mako314 is offline
stacking the evo and the 10K will not cuase any problems you will just have to watch EGTs very close. to get a quicker spool up either disable the waistgate or adjust the waistgate actuator to open under more boost. if the gate is disabled keep an eye on your boost with the evo and 10K you will hit 25 or 30 lbs easy and this is hard on the turbo bearings.
Old 01-08-2007, 02:57 PM
well i hit 24 now stock i have a controlled leak in my wastegate. thank you for the input
