ABS Light - Ford Powerstroke Diesel Forum
Old 02-24-2009, 08:28 PM
ABS Light
So my ABS light has been on a while. I changed the rear sensor a while ago but I just put new front ones on when I did new front hubs. The light is still on what else could be causing a problem.
Old 02-24-2009, 09:18 PM
probally a busted vacuum line... does ur a/c blow through the dash vents?
Old 02-25-2009, 02:42 AM
Powerstroke Junkie
I would check the PCM for codes and ,make sure all ABS cables are attached at the back of the hubs.
NCH
Old 02-25-2009, 06:47 AM
NCH
Cables are good I guess I will have to get soembody to pull the codes.
Old 02-25-2009, 09:39 AM
Does it still shut off each time you restart the truck and reilluminate after a short distance of driving, like 10 feet? Or always on?
Old 02-25-2009, 09:45 AM
It will come on about 15 seconds after cranking the truck. Before I even move. The light goes off while cranking then comes back on 15 seconds later.
