Old 01-04-2007, 04:57 PM
Robert11 Robert11 is offline
Quadzillia Commander
How does it work? Where do the readings come from? Are there any probs? Does it just plug in and bam you now have access to all the guages you could want?
Old 01-04-2007, 05:25 PM
sea71 sea71 is offline
The Commander is all your gauges in one, and much more! It comes with the necessary wiring harness and connectors to hook it up. The instructions have pictures and are easy to follow. Very nice product, IMO.
Shane
Old 01-04-2007, 05:33 PM
Oh, very cool. Thanks.
Old 01-04-2007, 06:08 PM
Logan Logan is offline
The Fat Mod
The basic kit comes with depending on application...Pyro, Trans Temp, Boost, and depending on 7.3 or 6oh, Coolant temp for the 6er and oil temp for the 7.3.
There are also other probes you can buy, and monitor up to seven things at once, you can only see four at once, but you can monitor 7.
You can also hook it up to the lap top and do data logging, it will give you Max values on whatever it is you are monitoring.
So if you do a 1/4 mile run, and want to see what your max boost or whatever was, just goback into it and pull it up, pretty cool I think. I love mine.
Old 01-04-2007, 06:11 PM
Jon
Tournaments Won: 1
Posts: n/a
The only
thing you have to worry about is if your fat fingered friend gets in your truck and messes with your settings. sorry Logan.
Old 01-04-2007, 06:18 PM
The Fat Mod
Hahaha, its all good, you can play with my toys till ya get your own
Old 01-04-2007, 06:20 PM
Jon
Tournaments Won: 1
Posts: n/a
I'm gonna be the first
to say that what Logan just said sounds a little weird but its not how it looks.
Old 01-04-2007, 06:22 PM
The Fat Mod
LMAO, ok yeah, its not what it sounds like
Old 01-04-2007, 06:28 PM
Jon
Tournaments Won: 1
Posts: n/a
Logan may wish it to be
But i'm to much cowboy for that feather fluffer.
