transmission cooler - Ford Powerstroke Diesel Forum
Old 02-20-2009, 09:36 AM
transmission cooler
what is the biggest cooler i can get for my 2003 f250 7.3
length,width,and thickness? and be able to leave the stock one on
Old 02-20-2009, 09:52 AM
i dont know your answer but you can bolt a 6.0 one in there and its bigger and doesnt take anything to do
Old 02-20-2009, 09:58 AM
i was reading on here i can do that, i was just wanting something alot bigger
Old 02-20-2009, 03:08 PM
Have you saw the 6.0 one? It's rather large compared to the stocker 7.3 one. And that's an understatement.
Old 02-20-2009, 03:33 PM
i got one from autozone and it is about half the size of the radiator, and I left the stock one in place.
Old 02-20-2009, 04:11 PM
Send a message via AIM to Stroked7.3
Get a TruCool 40K ande mount it right in front of your radiator. I just had one installed with my new tranny build and my temps dont go over 150 now.
Old 02-20-2009, 04:12 PM
the 6.0L is pretty big... i dont think you need anything bigger than that.. if your getting really hot temps with a 6.0L cooler in their then you have bigger problems
Old 02-20-2009, 04:51 PM
I dont know how much the 6.0 coolers are going for now. Bt my trucool only ran me $120 and came with all the hardware and hoses needed to plumb it inline.
Old 02-20-2009, 05:01 PM
The 6.0 cooler is just a drop in bigger cooler that takes place of the stock 4R100 cooler. The only complicated part is finding 3/8 to 1/2 barb adapters.
Old 02-20-2009, 05:52 PM
JJR JJR is offline
I added another tranny cooler inline with the factory one long before the 6.0s were even around and have had no problems with this setup. It is mounted in front of everything top left side of the radiator. Temps never climb above 150 solo 180 towing. Don't know what size it is but it measures about 12"x12". Got it for free so I figured I would try it. I did get my temp up to 250 once but that was driving it up Pikes Peak(14,111 ft.). Long pull, torque converter doesn't lock, and not alot of airflow through the coolers at that speed. I felt better about it after passing numerous cars and minivans that had their tranny's overheat and boil over though. You know it is a common occurence when the park rangers carry cases of tranny fluid in their trucks. Bottom line is any thing you add or change to is going to be an improvement over the stock one alone.
