High Pressure Oil Pump R&R $1200?
My son is looking at a 2002 PSD 7.3 and the seller said that there was a drip coming from the high pressure oil pump...and it could last a month or a day or forever before it needs replacing.
Anybody know whether this is a DIY job for an amateur? Is this a $1200 job or was that just stealer talk? |
Well there is a new HPOP that is better than stock and I believe cheaper. If you are not afraid to dive in with some wrenches. you can probably do it for around $600.00. But there is a waiting time to get this pump.
Diesel Site Adrenalin HPOP. |
Anybody have a photo or two of where this pump is on a 7.3L?
Also, szyd, where would I want to go to find one of these newer pumps? What happens when the pump dies, is it all of the sudden or progressive? |
If you can't post a photo, please send it to rs pickering at the gulftel.com site
There will be no space between the rs and the rest of the name... Rick |
There is a thread on the process i will look for it for you.
Ford's full list on an HPOP is 850 plus a 150 core charge. If you can get it for cost it's 607. It's not really a hard job.
I
a thread for you Modded 17* HPOP install has begun.
That thread is for an OBS but you should be able to get the idea on what is done.
The HPOP is located in the front of the engine valley directly beneath the fuel bowl. A DIYer can do the r&r, but it does require some specialty tools, if you are interested send me a pm and I can give you detailed instructions including what tools you will need. Here are some pics of the hpop.
The oil leak is likely two small o-rings that seal the two outlet pipes to the HPOP. Get some from a hose shop for under a dollar.
