2000 250 with bad front bearing - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-14-2009, 02:56 PM Thread Starter
I need info. My front wheel bearing is shot and I'm looking for a replacement on-line. Everything I see has the ABS feature, mine does not. Will an ABS version work? I have a 2000 250 Super Duty with the 7.3. Can these things be rebuilt (at home?) I only see hub assemblies.
ROLLING ROCK is offline
post #2 of 9 Old 02-15-2009, 01:02 PM
pjwoolw's Avatar
Check the Motorcraft site. Pretty comprehensive. You can search by vehicle or VIN number. If it is a hub assembly type your stuck buying the whole assembly. To my knowledge they are not rebuildable.
Good luck!
Pete in San Ramon
2005 F250 6.0 4X4 Lariat CC short bed (stock)
1997 F250 7.3 4X4 XLT Reg. cab (stock)
1986 F250 6.9 4X4 XLT Gone but not forgotten
pjwoolw is offline
post #3 of 9 Old 02-15-2009, 01:13 PM
duct tape & zip ties
bigcountrysg's Avatar
Check this website.
1A Auto: Aftermarket Auto Parts, Car Parts, Replacement Auto Body Parts, Truck Parts
You can get a pair of wheelbearing assemblies there for your truck. At the cost of one wheelbearing assembly from anywhere else. I have been running there wheel bearings for 2 years now with no problems.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #4 of 9 Old 02-15-2009, 04:24 PM
ROLLTIDE72's Avatar
Originally Posted by bigcountrysg View Post
Check this website.
X2 for this site. I just replaced both sides on my 02 4x4. Wasnt bad except for the Knuckle Hub Seal on the first side. Then I figured it out and the second side was a breeze.
02 Larait Crew Cab 4x4
Zoodad
Leveling Kit
315 BFG A/T
DIY 6637
HPX Crossover Line
ITP Overboost Annihilator
Coolant Bypass Filter
Foil Delete
Bellowed Up-Pipes
4" TB MBRP
ROLL TIDE ROLL!!!!
"This is my GLOCK, There are many like it but this one is MINE.
Originally Posted by bdpprocessors View Post
idk there shouldnt be anything loose its got a load of hp atleast 500 proly close to 6 idk i'll look under there tmrw
ROLLTIDE72 is offline
post #5 of 9 Old 02-15-2009, 04:58 PM Thread Starter
Thanks guys, I found the part at 1A Auto. Where would you advise me to get the seals? I think I am looking for F81Z-3254-CB and F81Z-1S175-HCA. I was gonna call the Dealer. In case you haven't figured it out, I am new to this Forum (and the net in general) but man it's a beautiful thing. I really appreciate the effort guys like you have put into this data base. I think I'm gonna through my Chilton's away!!!!
post #6 of 9 Old 02-15-2009, 05:07 PM
ROLLTIDE72's Avatar
Well I got the yellow Vacuum o rings, the knuckle seals and the 4 knuckle studs (per side) from the dealer. The studs and the yellow rings are cheap but the knuckle seal are about 45 bucks each and that is in line with a few websites I looked at.
Zoodad
Leveling Kit
315 BFG A/T
DIY 6637
HPX Crossover Line
Foil Delete
Bellowed Up-Pipes
4" TB MBRP
ROLL TIDE ROLL!!!!
post #7 of 9 Old 02-15-2009, 07:34 PM
The seal that costs 45 dollars is the vacuum seal. If you do not care about the auto locking hubs. Then you do not need to replace those seals.
2002 7.3L burnt
post #8 of 9 Old 02-15-2009, 07:42 PM
ROLLTIDE72's Avatar
I dont comepletely agree with that statement. If your knuckle seal is worn it will allow dirt and water to enter the knuckle cavity and get into the needle bearings. That can ruin the stub axle and needle bearings. Look around for the special tool required to install it. It can be done without the tool.
Zoodad
Leveling Kit
315 BFG A/T
DIY 6637
HPX Crossover Line
Foil Delete
Bellowed Up-Pipes
4" TB MBRP
ROLL TIDE ROLL!!!!
post #9 of 9 Old 02-15-2009, 08:01 PM
raptorian700's Avatar
Send a message via Yahoo to raptorian700
if your new bearing has abs and yours doesnt just cut the abs wire it will work just fine!
raptorian700 is offline
