fan hub nut removel - Ford Powerstroke Diesel Forum
Old 02-12-2009, 08:08 PM
fan hub nut removel
hey guys,i'm getin ready to change out my water pump on my 01 crew cab and was wanting to know if the hub nut that holds on the fan clutch has standard threads or backward threads?The hanes mannual said it had backward threads but i wanted to ask yall to make sure......thanks for any info.
Old 02-12-2009, 08:32 PM
I just replaced the water pump on my early 99 and the fan was right-handed thread. I also just noticed the other day that on my fan shroud, on the driver's side it says the the fan is right-handed thread.
Mike
Old 02-13-2009, 03:34 AM
thanks mat,just wanted to make sure before i started turnin hard on the nut and find out i was going the wrong way.
Old 02-13-2009, 03:41 AM
duct tape & zip ties
I used a cutting torch and replaced the fan clutch when I did my water pump.
